| ASUStek Discuss the latest ASUStek products |
Asus P6T7 WS SuperComputer Rig
ASUStek
25-08-2009, 04:08 PM
Bronze Member
Potenza rep: 7
Quote:
Originally Posted by Woody
@alipik
I'm building this rig for "Cypress", ATI's new RV870 DX11 vidcard. The 4870's I had lying around so I used them here...
RV870 is due out September 10, 2009...
HTH.
what do u mean by cypress?
25-08-2009, 09:53 PM
Gold Member
Potenza rep: 0
"Cypress" is the codename for what is supposed to be Radeon 5800 series, ATI's next geeration DX11 high-end vidcard.
To replace this...
HTH.
26-08-2009, 11:30 AM
Bronze Member
Potenza rep: 7
do u face any hurdles with the current card?
26-08-2009, 01:48 PM
Member
Potenza rep: 7
Does the south chipset get that worm that you had to use a fan on it? The radiator on it is pretty large does it not cope with the heat?
__________________
Gigabyte GA890XA-UD3 | AMD Phenom II 905e 4x2,5Ghz | Scythe Ninja | 4x Kingston 2048MB 1600Mhz HyperX | ASUS Radeon HD5770 1024MB | 2xSamsung 500GB 2,5'' | Chieftec SMR-250U mobile case with 100GB Hitachi SATA hdd| Gigabyte GT Odin 550W | CHIEFTEC WH-01B-B-500 | Benq V2410
Windows Vista x64
27-08-2009, 11:53 AM
Gold Member
Potenza rep: 0
Quote:
The two NF200s do get quite hot ( I touched the HS to find out...ouch!). It's on an open jig, so the expected airflow across it ( such as would be inside a case) has to be done using separate fans ATM.
I do plan a more extensive cooling solution, when I'm done with the current testing/benching.
HTH.
27-08-2009, 01:46 PM
Member
Potenza rep: 7
Are all PCI-EX lanes connected via those two NF200's? Would it be possible to measure if there is any legacy when working across those two bridges? (ie crossfire/sli across two bridges and across one bridge)
__________________
Windows Vista x64
28-08-2009, 06:49 AM
Gold Member
Potenza rep: 0
Indeed increased latency is a concern. Such has been observed using SLI/Tri-SLI on NF200 vs X58 mobos.
Here however, the sheer horsepower of x16 *4 vidcards should make up for it :)
HTH.
28-08-2009, 06:56 AM
Gold Member
Potenza rep: 0
01-09-2009, 02:14 PM
Gold Member
Potenza rep: 0
01-09-2009, 04:41 PM
Member
Potenza rep: 7
The vidcard to use for this mobo...:
Serious pow-ah!...
It's a brick...
^0^
Do you have more of those :) it would be nice to see how they perform in SLI :P
Are you going to use this card in the rig or are you waiting for amd to show their new product??
__________________
Windows Vista x64
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
