Custom Search
Go Back   OCWorkbench Lifestyle and Tech Forums > PC Problems, Mainboard and Graphics card troubleshooting > ASRock (AMD Boards)
ASRock (AMD Boards) Support forum for ASRock products. This channel is for AMD boards.
lookin for a NB hs/f
ASRock (AMD Boards)
Reply
Thread Tools
  #11
Old 22-05-2006, 10:08 PM
warmonger warmonger is offline
Member
Potenza rep: 0
warmonger is an unknown quantity at this point
Post
how close are ther capacitors around your NB? i've got atleast one cap touching the lower front edge of the ns base, which leaves no room for anything larger than a zalman base
__________________
http://img117.imageshack.us/img117/8...ckdeathec5.jpg
Lian Li PC65b; A8R32MVP(0701); X2 4800+/Si128;EAH2900XT; Ultra X2 550w; 2GB OCZ Gold Ed.; DDR400; WD3200KS, WD800JB
  #12
Old 23-05-2006, 09:57 AM
persnikitty's Avatar
persnikitty persnikitty is offline
Member
Potenza rep: 0
persnikitty is an unknown quantity at this point
Post
Ah, gotcha. 939SLI32 is fairly clear around the NB's immediate vicinity, but not overly so. Thermaltake's Crystal Orb and Vantec's Copper chip cooler won't fit at all due to stuff in the way. Also, the Northpole or XE will not work on the SB as there's some serious crowding there. For that I use Thermalright's HR-05 though it's quite a bit higher than 47mm but does have a very small footprint which just covers the chip.
__________________
What don't kill me will eventually.
OCWorkbench
  #13
Old 24-05-2006, 04:57 AM
Member
Potenza rep: 0
Post
yeah, the HR05 is angled too, ain't it. that might work
edit: read your review . i think one from asetek might work better on a 1695 rather that the HR05
__________________
  #14
Old 24-05-2006, 06:30 AM
Member
Potenza rep: 0
Post
Asetek? The vapochill micro is a cpu cooler. Perhaps you're thinking of the Force Chipset cooler which is angled and somewhat adjustable. I did look into that one and found it wouldn't work well with the 939SLI32 due to mobo components getting in the way.
__________________
  #15
Old 24-05-2006, 09:12 AM
Member
Potenza rep: 0
Post
yeah, thought it was for chipsets. silly me:D. that force cooler just might fit in with the look of the rest of my rig
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
HOW CAN U TELL THE CPU CODE other than by lookin on it EmAzY ECS#2002 (精英#2002) 6 18-03-2002 07:33 PM
Lookin for Fixed freq vid card pigskin Buy & Sell (International) 2 27-02-2002 11:02 PM
lookin' for a winner wymjym ECS#2001 (archive) (精英#2001) 0 07-10-2001 11:52 AM
lookin' for info on everyting grim122 General Mainboards/CPU/Chipsets/OC-MOD 9 07-04-2001 01:47 AM
