| EVGA, Supox, EPoX support forum eVGA, SUPoX mainboard |
Epox 9NDA3+ Socket 939 NF3 Ultra board
18-08-2004, 05:07 PM
Junior Member
Potenza rep: 0
Quote:
Originally posted by Bluetooth:
If you can propvide me with all the xpensive CPUs, I can do a test
I wish I had them so I could test them myself [img]smile.gif[/img]
__________________
EPoX 9NDA3+ - X2 4400+ @ 2.4ghz 0 2GB PC4400 <br />Abit AV8 - A64 3500+ @ 2.5ghz Air - 2GB PC4400<br />DFI NF4 Ultra-D - Opty 165 @ 2.5ghz - 2GB PC4000
18-08-2004, 10:47 PM
Silver Member
Potenza rep: 0
Quote:
Originally posted by RayvenX:
...That's not entirely a good idea: You can't boot directly from RAID 0 software partitions under Linux, and CPU utilisation for anything more complex than RAID 0 or 1, or 0+1 is uslessly high for most purposes (Such as RAID 5, where RAID actually starts to offer a useful performance benefit AND a useful integrity benefit)... Hardware RAID still has a long life ahead of it.
Getting off-topic here, but anyways...
As you know, RAID 0 (striping) offers no redundancy at all, so most users avoid booting/hosting the root filesystem on a RAID 0 device. That applies not only to software RAID but also to hardware RAID. Linux can boot from software RAID 1 (mirroring).
On modern K8/Xeon systems the use of software RAID 5 or above in a Linux system does not show any significant impact on CPU utilisation. But most people who actually use RAID 5 or above on Opteron/Xeon systems invest in a separate RAID controller card. [img]tongue.gif[/img]
What I meant by my initial remark is: Linux users who buy the Epox 9NDA3+ mainboard won't miss the hardware (assisted, not true hardware) RAID controller found in other, more expensive Epox boards.
__________________
K7S8XE+, OCW Beta BIOS 1.91a, Barton 2500+ @ 2.2GHz, 1.75V Vcore, 1 x 512Mo noname PC3200 RAM, Zalman CNPS7000A-AlCu, 300W Enermax PSU.<br />Rock-stable @ 42/47C Sys/CPU temps (summer).
21-08-2004, 01:49 AM
Rookie
Potenza rep: 0
Oke kinda new here, but is there a launch date yet because this board has my interests. But if it takes to long I'll go for teh MSI Neo plat.
21-08-2004, 10:13 PM
Member
Potenza rep: 0
Yes, Bluetooth, I agree with your opinion. But, as for performance comparison, I usually compare the following SuperPi results:
1.1M with all stock & default setting basis
2.1M with all stock & 2400—2466.66Mhz limited clock speed basis--so-called Athlon24-GP competition in Japan
3.1M & 8M with maxed out setting without any modification—using ClockGen, SetFSB & etc.
Recently, I add 32M with Prometeia &/ Vmod maxed out setting basis.
PS
It was so nice to be in Greece for attending Opening Ceremony of Olympic Games; Judo & Swimming competitions especially witnessed 3 gold medals for Japan in first two days. [img]smile.gif[/img]
The rest, unfortunately it was all for business…… :(
23-08-2004, 12:15 PM
Junior Member
Potenza rep: 0
Quote:
Originally posted by Omega65:
</font><blockquote>quote:</font><hr />Originally posted by Bluetooth:
The increased FSB won't bring your anything more because the multiplier has to be adjusted downwards.
Actually 8x 250mhz = 2.0ghz should outperform 10x 200mhz = 2.0ghz.
But I was suggesting Max FSB/Max Clockspeed benchmarks.</font>[/quote]Some Data to back up my opinion
Chaintech VNF3-250 Review pg8 A64 3200+ 2.0ghz 1MB
1) 200mhz x 10 = 2000mhz
2) 250mhz x 08 = 2000mhz
3) 247mhz x 10 = 2470mhz
FarCry
1)108.56
2) 114.98
3)133.88
UT 2004
1)188.88
2) 194.49
3)217.00
3DMark 2001
1)19690
2) 20166
3)21555
Aquamark
1)43312
2) 44379
3)45513
__________________
23-08-2004, 05:33 PM
The one
Potenza rep: 10
As I have said, there is not much difference.
24-08-2004, 02:13 AM
Junior Member
Potenza rep: 0
To me it looks like the gains you get from a whole entire speed grade jump (+200mhz) just by changing the FSB.
Well this horse is dead (drops bat) [img]smile.gif[/img]
__________________
24-08-2004, 02:51 AM
The one
Potenza rep: 10
Not a lot if you lower the multiplier.
24-08-2004, 05:29 AM
Junior Member
Potenza rep: 0
I am eager to check out an AMD 64 system in action but I don't know anybody locally who has one yet. Sure, there are some of the HP's, Compaq's, etc.. in the stores but you can't really do much with them there.
This EPoX sounds like a great board though so I look forward to hearing more about it as it gets in the hands of end users.
I probably won't upgrade to a 64 until sometime next year and will hopefully have a new EPoX socket A to keep me going for awhile. ;)
Kirk
__________________
PC #1<br />Athlon 3000+@2162MHz(13x166) <br />Asus A7N8X Deluxe(that I want to swap for a new Epox board) <br />1GB PC 3200 Corsair XMS <br />MSI RX9800 PRO-TD128 <br />120GB Western Digital HD<br />Antec Full Tower Steel Case w/420 watt PSU<br />Dell 2001FP 20.1\" LCD<br />Win XP Pro w SP1<br /><br />PC #2<br />Athlon 2600+@2161MHz(12.5x173)<br />EPOX EP-8DRA<br />Asylum Gerforce Ti4200 128MB<br />512 MB PC2700 DDR RAM<br />120GB Western Digital HD<br />Antec Lanboy Case w/350 watt SmartBlue PSU<br />Win XP Pro w SP1
13-09-2004, 01:44 PM
The one
Potenza rep: 10
I think Socket A is coming to end of life.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
