Custom Search
Go Back   OCWorkbench Lifestyle and Tech Forums > PC Problems, Mainboard and Graphics card troubleshooting > EVGA, Supox, EPoX support forum
EVGA, Supox, EPoX support forum eVGA, SUPoX mainboard
Epox 9NDA3+ Socket 939 NF3 Ultra board
Reply
Thread Tools
  #101
Old 26-10-2004, 03:30 AM
pweltz pweltz is offline
Rookie
Potenza rep: 0
pweltz is an unknown quantity at this point
Post
Quote from Anandtech's review of this board:
It should also be mentioned that when we first received the Epox 9NDA3+, we could only run memory at 1T in slots 3 and 4. Any attempt to run at a 1T or Auto Command Rate setting failed boot. Epox supplied us an updated BIOD that did fix this problem, but the new BIOS did not fix our other concern. About 50% of the time, the Epox board with either BIOS would fail on reboot and freeze at the first BIOS screen. We were always able to continue a boot by hitting reset or turning the computer off first, but these failed reboots were time consuming and very annoying for a production board. Epox needs to fix this issue with a BIOS update or they will get many complaints from end users.
I guess I'm not the only one having 1T memory problems and boot issues.
  #102
Old 26-10-2004, 04:10 AM
fredyama fredyama is offline
Member
Potenza rep: 0
fredyama is an unknown quantity at this point
Post
So strange that seems I am the only one having no problems to run this mighty fine MoBo.....
Please take a look at my fastes time ever got for SuperPi 32M here
OCWorkbench
  #103
Old 26-10-2004, 05:04 AM
Member
Potenza rep: 0
Post
Forgot to mention that CPU temperature reading seems to be way off; around 36--48 deg C even under Prometeia cooling before and after running SuperPi.
Since it has never hanged nor rebooted, am not so concernd about those temperature readings.
  #104
Old 28-10-2004, 12:21 AM
-=[A*R*D*O*R]=- -=[A*R*D*O*R]=- is offline
Rookie
Potenza rep: 0
-=[A*R*D*O*R]=- is an unknown quantity at this point
Smile
Just got the board and took some photos.
And in case someone what's to draw in the mods cause I'm not sure yet.
Image Vcore (100k VR pin 10 to ground )
Image Vdimm (50k VR pin 6 to ground )
  #105
Old 28-10-2004, 01:46 AM
Member
Potenza rep: 0
Post
Thanks A*R*D*O*R for nice photos. It sure looks identical to my MoBo assuming you've got it from the same net shop starting with K.
Yes, have already done these Vmod except I used 10k VR instead for Vdimm.
The pin positions are identical to 8KDA3+ although it uses ISL6569CB instead of ISL6559CB for Vcore.
I believe this MoBo has Voltage Over Protection for Vcore like 8KDA3+ that it shuts down automatically over 1.93v setting.
Look forward to your findings on this Mobo.
  #106
Old 29-10-2004, 04:22 AM
gonzos-revenge gonzos-revenge is offline
Rookie
Potenza rep: 0
gonzos-revenge is an unknown quantity at this point
Post
Got my 9NDA3+ today here in Germany. But it will take a couple of days to change it against my MSI.
But the most important thing to tell you is:
There is a new Bios on the TW website:9nd34a26
gonzos-revenge
  #107
Old 29-10-2004, 12:01 PM
The one
Potenza rep: 10
Post
Anyone wants to write a mod guide for this board?
__________________
Follow us now at :
  #108
Old 29-10-2004, 11:40 PM
Chriscc Chriscc is offline
Rookie
Potenza rep: 0
Chriscc is an unknown quantity at this point
Post
Quote:
exactly is available on epox website, is it the release of the beta bios updated by bluetooth?
http://www.epox.com.tw/eng/support.php?ps=322&type=1
  #109
Old 30-10-2004, 12:38 AM
The one
Potenza rep: 10
Post
It is not from me.
__________________
Follow us now at :
  #110
Old 04-11-2004, 11:58 PM
Rickstur Rickstur is offline
Rookie
Potenza rep: 0
Rickstur is an unknown quantity at this point
Post
Bluetooth or anybody, does it matter (performance wise) if you put your memory in dimm # 3 and 4 instaed of dimm # 1 and 2. This is because i am planning on buying a Thermalright xp-120 but with this cooler on a 9NDA3+ you are not able to use dimm # 1.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
[req] Epox nforce4 ultra board? Raziel EVGA, Supox, EPoX support forum 1 19-11-2004 04:54 AM
Which EPoX Socket 754 board do you use? bluetooth EVGA, Supox, EPoX support forum 8 15-09-2004 04:11 AM
OCW Review : EPoX 9NDA3+ A64 NF3Ultra board bluetooth News / Announcements 0 20-08-2004 02:55 PM
EPoX 9NDA3+ PressRelease bluetooth EVGA, Supox, EPoX support forum 2 06-08-2004 04:01 AM
EPoX unveiled K8 939 socket board — EP-9NDA+ bluetooth EVGA, Supox, EPoX support forum 9 22-07-2004 11:22 PM
