Custom Search
Go Back   OCWorkbench Lifestyle and Tech Forums > PC Problems, Mainboard and Graphics card troubleshooting > General Mainboards/CPU/Chipsets/OC-MOD
General Mainboards/CPU/Chipsets/OC-MOD Discuss all brands of mainboard problems here. CPU/Chipset issues. Post brand specific questions in the brand channels. Subforums : ABIT, ASUS, Chaintech, EPoX, MSI, Jetway, Chipsets, Extreme Overclocking.
Need some advice on buying DDR mobo and stuff...
Reply
Thread Tools
  #1
Old 11-01-2001, 04:58 PM
Mysterio
Posts: n/a
Post
as above...
I can't wait to get one of it...hehe...
anyway, I've a question to ask u guys..
I'm planning to get the GA-7DXC and a 1.1Ghz Thunderbird...
Is it possible to run the system wholly on 200Mhz FSB, I mean not just the RAM but also the CPU ??
and yes, one more thing, how much more performance can be gained if we used a PC2100 RAM instead of PC1600??
I'm still a bit confused here....
anyone can enlighten me ??
  #2
Old 11-01-2001, 07:53 PM
overclocker
Posts: n/a
Post
Get the GA 7DX, not 7DXC. The former supports 266mhz while the latter only 200Mhz FSB
OCWorkbench
  #3
Old 13-01-2001, 04:47 AM
Dazz Dazz is offline
Bronze Member
Potenza rep: 0
Dazz is an unknown quantity at this point
I've got a question? Can you run Nvidia TNT2, GF256, GF2 cards on any DDR board's (AMD 760, ALI, VIA!!!with 4x AGP enabled without any problems i.e no hacking, crashing etc
Intel Celeron 500@600Mhz
ASUS P3V4X board
10.1GB IBM Deskstar HD
Elsa Erazor III LT 32MB
192MB Pc-100 SD-Ram
Creative Labs SoundBlaster 128
Creative Labs 2x 12MB Voodoo2
Creative Labs FPS1500
Creative Labs 5x DVD-Rom
Creative Labs 52x CD-Rom
MS Sidewinder Force FeedBack 2
MS Strategic Commander
MS Intellimouse Explorer
MS Windows ME
  #4
Old 13-01-2001, 04:51 AM
overclocker
Posts: n/a
Post
I have been using Gefroce GTS2 on ALi MAGiK1 (Iwill KA266R) and Gigabyte 7DX (AMD 760) no prpoblems at all. at 4x
  #5
Old 13-01-2001, 05:04 AM
Bronze Member
Potenza rep: 0
Thumbs down
Great thats what i wanted to hear now i will just have to wait till Abit brings theirs out
  #6
Old 13-01-2001, 06:33 AM
Bronze Member
Potenza rep: 0
Oh yes as you know that Pc1600 can go to Pc2100 CAS 2.5, but do you think that Pc2100 CAS 2.0 will do 333Mhz?
So it will look something like this
AMD K7 700 = Overclocked to 1000Mhz with 6.0x 166Mhz DDR FSB
ABIT G7-RAID = AMD 761 board
128MB Pc2100 CAS2 = 133Mhz DDR SD-Ram o/c 166Mhz
Do you think That is possible? also will it switch from 1/3 to 1/4 so that the AGP & PCI BUS's an't overclocked?
Thanks Overclocker
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Quick chipset buying advice! jedijunk ASUStek 14 23-05-2007 05:00 AM
Buying 8k9A2+ & XP2400+ &Geil400Cas2. Any advice? HoTShoT.BH.MG EVGA, Supox, EPoX support forum 1 03-12-2002 01:42 AM
Need advice about buying ram sabwafare2001 ECS #2002-2 1 13-07-2002 05:46 AM
CD-ROM Drives buying advice EVO Graphics cards, HDD, SSD, DDR and Peripherals 11 26-05-2001 03:50 AM
Mobo Buying Advice primus General Mainboards/CPU/Chipsets/OC-MOD 15 18-05-2001 04:01 PM
