Custom Search
Go Back   OCWorkbench Lifestyle and Tech Forums > PC Problems, Mainboard and Graphics card troubleshooting > ABIT
ABIT Post your questions on ABIT mainboards.
ABIT AT7 MAX2, AMDXP 2200+ not stable @ 2400+ :(
ABIT
Reply
Thread Tools
  #1
Old 07-11-2002, 10:35 PM
nafsruh nafsruh is offline
Rookie
Potenza rep: 0
nafsruh is an unknown quantity at this point
Red face
Hi!
I tried 148fsbx13.5= 2000MHz. It won't boot at 1.65vCore.
It will boot at 1.70vCore. But wont get me into windows.
It will only get me into windows at 1.80vCore. [img]redface.gif[/img] But isn't stable and just freezes; the mouse cursor wont move anymore.
So I went all the way up to 1.90vCore, but still freezes on me :(
My dividers are set to 5:2:1
Is my CPU that bad?
Please help me out!
Thnx.
[edit]
I think my stepping is somethinge like AGUIA
Dont know for sure.
[/edit]
  #2
Old 08-11-2002, 01:16 AM
gymyforte gymyforte is offline
Silver Member
Potenza rep: 0
gymyforte is an unknown quantity at this point
Post
Why do you use 5:2:1 divider for ~148 fsb?For this settings pci is ~29,6mhz! 5:2:1 settings should be used above~160 fsb!What temp have your cpu for this settings,also.
OCWorkbench
  #3
Old 08-11-2002, 10:42 AM
Rookie
Potenza rep: 0
Arrow
<blockquote>quote:</font><hr>Originally posted by gymyforte:
Why do you use 5:2:1 divider for ~148 fsb?For this settings pci is ~29,6mhz! 5:2:1 settings should be used above~160 fsb!What temp have your cpu for this settings,also.<hr></blockquote>
My CPU internal temp is 61(!) Outside the CPU it's 49! (celsius)
That's with 1.80vCore.
So I should use divider 4:2:1?
My CPU cooler is from CoolerMaster. It can handle a 2600+ CPU max.
Maybe my ATI9700pro won't be able to handle the AGP speed? 148/2= 74MHz.
I'll try more and keep u all updated.
System specs:
AMD xp 2200+
512 DDR333 Nanya
ABiT AT7 MAX2
ATI 9700pro
  #4
Old 08-11-2002, 06:19 PM
Silver Member
Potenza rep: 0
Post
First , your cpu temp is too high! For a good ocing should be under~45C!I don't know anything about your cooler but however should be with only copper heatsink! About agp speed:I can run with my Radeon 8500@166-4:2:1(agp~83mhz!)and its stable(3D&2D).I can load windows @~172-4:2:1-agp=86mhz(freeze in 3D but stable in 2D).
My specs:
Abit KX7-333(no raid)
Xp2000+@1815(173x10,5)@1,75v
Thermalright SLK 600 with delta fan
2x128 Kingmax pc [email protected]/2/5/2
Gigabyte Radeon 8500
  #5
Old 08-11-2002, 09:20 PM
onepagebook onepagebook is offline
Junior Member
Potenza rep: 0
onepagebook is an unknown quantity at this point
Post
1. your T-bred should be "a" version
2. if you run 147 fsb, that means that you got 29Pci freq. most your PCI device or HD might not stand for that(too low). more, your RAM won't be stable either.
you might think about 12x166 then change pci divider to 5:2:1, so you got pci/agp=33/66
and your ram can run DDR333
my rig:
Abit AT7MAX2
AXP 2400+(B)@ 2800+ (13.5x166)
ATI Radeon 9700 pro
View Sonic VX900 Monitor
Apacer DDR333 256MB x2
Teac 552s cdrom
Plextor 401240a
Pioneer 106s slot DVD
WD 120gb x2 raid 0
TOP power 520w
ThermalTake case
  #6
Old 09-11-2002, 12:07 AM
Rookie
Potenza rep: 0
Arrow
Hey guys.
Thnx for the reply's.
Allright... what did you mean with "a" version of the CPU? The stepping?
The CPU cooler I have has an copper inlay and the sink itself is aliminum. It's rated up to 2600+
When I run the CPU at default speed and vCore the temp is 48 degree celsius full load. I don't think that is the problem.
My 3dmark 2001 SE score is:
13350
I checked out some reviews and that is a normal score.
So I'll first need to unlock my CPU to get 12x166
Do you have any links on how to do that?
Thnx.
  #7
Old 09-11-2002, 04:57 AM
Junior Member
Potenza rep: 0
Post
I don't think you need to!
If you need, just use conductive pen and connect the last bridge of L3
Oh, you know what , don't have to fill the pit, just do it curvely.
see this(note , this is not L3,)
  #8
Old 09-11-2002, 05:01 AM
Junior Member
Potenza rep: 0
Post
http://www.ocworkbench.com/ocwbcgi/u...c&f=7&t=000445
  #9
Old 09-11-2002, 05:52 AM
Rookie
Potenza rep: 0
Post
Allright! You are great help! Thank you.
Now I need to find a conductive pen.
I'll try this in the weekend.
But what was this all about?
  #10
Old 09-11-2002, 05:56 AM
Rookie
Potenza rep: 0
Arrow
By the way.
What are your 3dmark 2001 SE scores?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
amdxp 2400+ cant run @ 2ghz CFW CPU/Chipsets - ATI, Intel, nVIDIA, SiS, ULI, VIA 3 02-10-2006 01:10 AM
ABIT IT7 Max2 users bluetooth ABIT 1 21-11-2004 12:38 PM
2400+ when OC say 2200? TomiOS ECS / PCChips 1 15-01-2004 11:32 AM
Abit KR7-RAID to Abit AT7-Max2 FSB Problems adie ABIT 1 29-05-2003 02:51 AM
ABIT IT7-MAX2 V2 Boot ? dan6400 ABIT 12 17-02-2003 12:37 PM
